メインコンテンツにスキップ
Dell Chromebook 11 3180 Touchpad Replacement
必要な工具と部品
  1. Dell Chromebook 11 3180 Touchpad Replacement, Back Cover: 手順 1、 1の画像 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Touchpad Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Touchpad Replacement: 手順 3、 1の画像 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Touchpad Replacement: 手順 4、 1の画像 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Touchpad Replacement: 手順 5、 1の画像 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Touchpad Replacement, Battery: 手順 6、 2の画像 1 Dell Chromebook 11 3180 Touchpad Replacement, Battery: 手順 6、 2の画像 2
    • Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
    • You can locate this cable by checking that its other end connects to the battery. It has black protective wrap.
  7. Dell Chromebook 11 3180 Touchpad Replacement: 手順 7、 1の画像 1
    • Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
  8. Dell Chromebook 11 3180 Touchpad Replacement: 手順 8、 1の画像 1
    • Lift the battery away from the computer to remove it.
    • If there is any resistance to the battery being removed, make sure that all of the screws have been properly removed and that nothing is blocking the battery.
  9. Dell Chromebook 11 3180 Touchpad Replacement, Touchpad: 手順 9、 2の画像 1 Dell Chromebook 11 3180 Touchpad Replacement, Touchpad: 手順 9、 2の画像 2
    • Unplug the touch pad from itself by lifting up on the connector and pull out the ribbon cable.
  10. Dell Chromebook 11 3180 Touchpad Replacement: 手順 10、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the five 2mm and single 3mm screws. Set the screws aside and note that they are for the touch pad.
    • One screw will be slightly smaller in size than the other five.
  11. Dell Chromebook 11 3180 Touchpad Replacement: 手順 11、 1の画像 1
    • Lift the touch pad, with it's bracket, away from the computer to remove it.
終わりに
作成者
3人の作成者と共同で作成されました。
Devon Paul
メンバー登録日: 04/26/17
1,206 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S22-G1, Livingston Spring 2017 Cal Poly, Team S22-G1, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S22G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 2,116
