はじめに
This guide demonstrates how to replace the touch pad of your device. The touch pad may become damaged or malfunction after extended use, and replacing it is very straightforward and should not take long.
必要な工具と部品
Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
Unplug the touch pad from itself by lifting up on the connector and pull out the ribbon cable.
もう少しです!
終わりに
