メインコンテンツにスキップ
Dell Chromebook 11 3180 Speakers Replacement
必要な工具と部品
  1. Dell Chromebook 11 3180 Speakers Replacement, Back Cover: 手順 1、 1の画像 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Speakers Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Speakers Replacement: 手順 3、 1の画像 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Speakers Replacement: 手順 4、 1の画像 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Speakers Replacement: 手順 5、 1の画像 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Speakers Replacement, Speakers: 手順 6、 3の画像 1 Dell Chromebook 11 3180 Speakers Replacement, Speakers: 手順 6、 3の画像 2 Dell Chromebook 11 3180 Speakers Replacement, Speakers: 手順 6、 3の画像 3
    • Locate and gently pull the wire harness (small plastic box with wires leading to black audio speakers) directly out of the connector on the motherboard.
    • Some components are not shown in pictures for simplicity. There is no need to remove any of the missing components to successfully remove the speakers.
  7. Dell Chromebook 11 3180 Speakers Replacement: 手順 7、 3の画像 1 Dell Chromebook 11 3180 Speakers Replacement: 手順 7、 3の画像 2 Dell Chromebook 11 3180 Speakers Replacement: 手順 7、 3の画像 3
    • Remove any existing tape attached to the audio wire you unplugged in the previous step.
    • Gently lift and remove speakers.
    • No screws should be removed
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
George Erie
メンバー登録日: 04/26/17
327 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S22-G1, Livingston Spring 2017 Cal Poly, Team S22-G1, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S22G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 648
