メインコンテンツにスキップ
Dell Chromebook 11 3180 Motherboard Replacement
必要な工具と部品
  1. Dell Chromebook 11 3180 Motherboard  Replacement, Back Cover: 手順 1、 1の画像 1
    • Set your laptop upside down on your work space.
    I usually skip most all of this and start with the bezel, disconnecting the screen wire AT THE SCREEN, and not at the motherboard. 4 screws around the bezel, and 4 screws in the screen. Leave everything connected and skip to step 12.
    Denton Holland - 返信
  2. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 2、 1の画像 1
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
    -coordinate color of bullet points with markup
    -perhaps say "...in the middle of the back cover" instead of "at"
    Daniel Leon-Gijon - 返信
  3. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 3、 1の画像 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
    -coordinate color of bullets with markup
  4. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 4、 1の画像 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 5、 1の画像 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Motherboard  Replacement, Battery: 手順 6、 2の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement, Battery: 手順 6、 2の画像 2
    • Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
    • You can locate this cable by checking that its other end connects to the battery. It has black protective wrap.
    -coordinate color of bullet with markup
  7. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 7、 1の画像 1
    • Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
    -coordinate color of markup with bullet
  8. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 8、 1の画像 1
    • Lift the battery away from the computer to remove it.
    • If there is any resistance to the battery being removed, make sure that all of the screws have been properly removed and that nothing is blocking the battery.
  9. Dell Chromebook 11 3180 Motherboard  Replacement, Motherboard: 手順 9、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement, Motherboard: 手順 9、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement, Motherboard: 手順 9、 3の画像 3
    • Lift the black clasp and gently pull on blue ribbon until it completely disconnects from the motherboard.
  10. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 10、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 10、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 10、 3の画像 3
    • Lift the black clasp and use the spudger tool to remove the ribbon so that it completely disconnects from the motherboard.
  11. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 11、 2の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 11、 2の画像 2
  12. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 12、 2の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 12、 2の画像 2
    • Locate and gently pull the wire harness (small plastic box with wires leading to the black audio speakers) directly out of the connector on the motherboard.
  13. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 13、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 13、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 13、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
    • Remove the metal shield protecting the black and white wires beneath it.
  14. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 14、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 14、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 14、 3の画像 3
    • Locate and gently pull up on the white and black wires to disconnect them from the motherboard.
  15. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 15、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 15、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 15、 3の画像 3
    • Locate and gently pull the wire harness (small plastic box with two pink, one orange, and two black wires) directly out of the connector on the motherboard.
  16. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 16、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 16、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 16、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the two 3mm screws.
  17. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 17、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 17、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 17、 3の画像 3
  18. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 18、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 18、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 18、 3の画像 3
    • Lift black clasp and gently pull on the back of the wire until it completely disconnects from the motherboard.
  19. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 19、 3の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 19、 3の画像 2 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 19、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the five 3mm screws.
  20. Dell Chromebook 11 3180 Motherboard  Replacement: 手順 20、 2の画像 1 Dell Chromebook 11 3180 Motherboard  Replacement: 手順 20、 2の画像 2
    • Gently lift and remove the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
George Erie
メンバー登録日: 04/26/17
327 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S22-G1, Livingston Spring 2017 Cal Poly, Team S22-G1, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S22G1
4 メンバー
8のガイドは作成済み
コメント 1 件
Dell Chromebook 11 3180 3189 uses a very special power jack connector, the power jack is soldering to a iron cover, people have to replace the whole part when the jack is broken/burnt, this is the correct part: https://www.dcincable.com/xnj46-0xnj46-c..., remember not to move the laptop while charging the battery, a good habit can make the laptop working longer.
Tom - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 30
今までの合計 3,701
