メインコンテンツにスキップ
Dell Chromebook 11 3180 Keyboard Replacement
必要な工具と部品
  1. Dell Chromebook 11 3180 Keyboard Replacement, Back Cover: 手順 1、 1の画像 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Keyboard Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Keyboard Replacement: 手順 3、 1の画像 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Keyboard Replacement: 手順 4、 1の画像 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Keyboard Replacement: 手順 5、 1の画像 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Keyboard Replacement, Keyboard: 手順 6、 1の画像 1
    • Disconnect the ribbon cable from the motherboard. To do this, lift up the black tab hinge securing the ribbon cable and pull the cable up and then out of the port.
  7. Dell Chromebook 11 3180 Keyboard Replacement: 手順 7、 1の画像 1
    • Release the keyboard from the body. To do this, push on the two keyboard release holes with something thin and cylindrical like a spudger or a pencil.
  8. Dell Chromebook 11 3180 Keyboard Replacement: 手順 8、 1の画像 1
    • Remove the keyboard from the body. To do this, use a plastic prying tool to get under the keyboard and pry it up from the computer body.
  9. Dell Chromebook 11 3180 Keyboard Replacement: 手順 9、 1の画像 1
    • Once you have separated the keyboard and the body using a spudger or plastic opening tool, use your hands to pull it away from and off of the computer.
終わりに
14 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Devon Paul
メンバー登録日: 04/26/17
1,224 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S22-G1, Livingston Spring 2017 Cal Poly, Team S22-G1, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S22G1
4 メンバー
8のガイドは作成済み
コメント 1 件
How I will fix the chromebook 11 now?
Federico Vazquez - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 26
過去 30 日: 51
今までの合計 7,639
