メインコンテンツにスキップ
Dell Alienware M17x R2 Hard Drive Replacement
必要な工具と部品
  1. Dell Alienware M17x R2 Hard Drive Replacement, Loosen the Four Screws: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Loosen the four captive screws that secure the primary hard drive (HDD0).
  2. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 手順 2、 2の画像 1 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 手順 2、 2の画像 2
    • Using the pull tab, slide the primary hard drive (HDD0) towards the back of the hard drive bay and lift it out.
  3. Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: 手順 3、 3の画像 1 Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: 手順 3、 3の画像 2 Dell Alienware M17x R2 Hard Drive Replacement, Removing Secondary Hard-Drive: 手順 3、 3の画像 3
    • If your computer has a secondary hard drive (HDD1): 1. Loosen the four captive screws on the secondary hard drive (HDD1). 2. Using the pull tab, lift the secondary hard drive (HDD1) out of the hard drive bay.
  4. Dell Alienware M17x R2 Hard Drive Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the four screws that secure the hard drive bracket to the hard drive.
  5. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 手順 5、 2の画像 1 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 手順 5、 2の画像 2
    • Slide the hard drive out of the hard drive bracket.
  6. Dell Alienware M17x R2 Hard Drive Replacement, Remove the Interposer: 手順 6、 2の画像 1 Dell Alienware M17x R2 Hard Drive Replacement, Remove the Interposer: 手順 6、 2の画像 2
    • Remove the interposer from the secondary hard drive (HDD1), if applicable.
  7. Dell Alienware M17x R2 Hard Drive Replacement, Connecting the Interposer: 手順 7、 2の画像 1 Dell Alienware M17x R2 Hard Drive Replacement, Connecting the Interposer: 手順 7、 2の画像 2
    • Connect the NEW interposer to the secondary hard drive (HDD1), if applicable.
  8. Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 手順 8、 2の画像 1 Dell Alienware M17x R2 Hard Drive Replacement, Sliding the Hard-Drive: 手順 8、 2の画像 2
    • Slide the hard drive into the hard drive bracket.
  9. Dell Alienware M17x R2 Hard Drive Replacement, Replace the Screws: 手順 9、 1の画像 1
    • Replace the four screws that secure the hard drive bracket to the hard drive.
  10. Dell Alienware M17x R2 Hard Drive Replacement, Placing the Hard Drive: 手順 10、 1の画像 1
    • Place the hard drive in the hard drive bay.
  11. Dell Alienware M17x R2 Hard Drive Replacement, Align and Tighten the Screws: 手順 11、 1の画像 1
    • If your computer has a secondary hard drive (HDD1), align and tighten the four captive screws that secure the hard drive to the hard drive bay.
    • Align and and tighten the four captive screws that secure the primary hard drive (HDD0) to the hard drive bay.
終わりに
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,309 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,984のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 13
今までの合計 2,120
