メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Alienware M11x R3 Keyboard Replacement
必要な工具と部品
    1. Dell Alienware M11x R3 Keyboard Replacement, Lower Case: 手順 1、 3の画像 1 Dell Alienware M11x R3 Keyboard Replacement, Lower Case: 手順 1、 3の画像 2 Dell Alienware M11x R3 Keyboard Replacement, Lower Case: 手順 1、 3の画像 3
      • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
      • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
      • Remove the bottom cover from the laptop.
      FixBotに聞いてみる
      コメントを追加
    1. Dell Alienware M11x R3 Keyboard Replacement, Keyboard: 手順 2、 1の画像 1
      • Unscrew the two circled screws holding the battery in place. These screws have retaining washers, so they won't completely detach from the device.
      FixBotに聞いてみる
      コメントを追加
    2. Dell Alienware M11x R3 Keyboard Replacement: 手順 3、 2の画像 1 Dell Alienware M11x R3 Keyboard Replacement: 手順 3、 2の画像 2
      • Next, unplug the battery cable (PD12) from the motherboard by gently pulling up.
      FixBotに聞いてみる
      コメントを追加
    3. Dell Alienware M11x R3 Keyboard Replacement: 手順 4、 1の画像 1
      • Now, remove the battery by gently pulling on the tab located between the two screws. The battery will pivot, and you will be able to completely detach the battery from the device.
      FixBotに聞いてみる
      コメントを追加
    4. Dell Alienware M11x R3 Keyboard Replacement: 手順 5、 2の画像 1 Dell Alienware M11x R3 Keyboard Replacement: 手順 5、 2の画像 2
      • Once the battery is removed, take out the two screws circled. These screws are labeled "M2x3 K" by engravings in the frame located next to their corresponding holes.
      • These screws will be completely removed. Keep them somewhere safe.
      FixBotに聞いてみる
      コメントを追加
    5. Dell Alienware M11x R3 Keyboard Replacement: 手順 6、 3の画像 1 Dell Alienware M11x R3 Keyboard Replacement: 手順 6、 3の画像 2 Dell Alienware M11x R3 Keyboard Replacement: 手順 6、 3の画像 3
      • Now, flip the computer back over. Above the "DELETE" key on the edge of the computer is a small indent. Here you will use the spudger to pry this plastic piece up.
      FixBotに聞いてみる
      コメントを追加
    6. Dell Alienware M11x R3 Keyboard Replacement: 手順 7、 1の画像 1
      • Push the monitor back as far as the hinges will allow.
      • Continue to pry the plastic piece off along the top of the keyboard. Remove this piece.
      FixBotに聞いてみる
      コメントを追加
    7. Dell Alienware M11x R3 Keyboard Replacement: 手順 8、 1の画像 1
      • Now remove the two screws located directly above the F3 key and the PAUSE key.
      • These screws will also be completely removed, so keep them in a safe place.
      FixBotに聞いてみる
      コメントを追加
    8. Dell Alienware M11x R3 Keyboard Replacement: 手順 9、 2の画像 1 Dell Alienware M11x R3 Keyboard Replacement: 手順 9、 2の画像 2
      • With both screws removed, gently lift up on the keyboard, and slide it towards the monitor. It will come out.
      • Caution: Do not tug too hard on the keyboard, as it has two fragile connection ribbons underneath that you do not want to tear.
      FixBotに聞いてみる
      コメントを追加
    9. Dell Alienware M11x R3 Keyboard Replacement: 手順 10、 3の画像 1 Dell Alienware M11x R3 Keyboard Replacement: 手順 10、 3の画像 2 Dell Alienware M11x R3 Keyboard Replacement: 手順 10、 3の画像 3
      • Now unlock and unplug the two ribbons cables underneath the keyboard. They are held in place by black locks.
      • To unlock them, gently slide a finger nail or spudger tool under them and lift up. You need to do this for both ribbons.
      • With the old keyboard removed, you can now install your new one and reassemble the computer!
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order while attaching the new keyboard.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Richard Maurice
メンバー登録日: 03/08/17
534 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 UMass Dartmouth, Team S3-G7, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S3G7
3 メンバー
65のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 57
今までの合計 2,340
