メインコンテンツにスキップ
Dell Alienware M11x R3 Battery Replacement
必要な工具と部品
  1. Dell Alienware M11x R3 Battery Replacement, Lower Case: 手順 1、 3の画像 1 Dell Alienware M11x R3 Battery Replacement, Lower Case: 手順 1、 3の画像 2 Dell Alienware M11x R3 Battery Replacement, Lower Case: 手順 1、 3の画像 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Battery Replacement, Battery: 手順 2、 1の画像 1
    • Ensure your Dell Alienware M11x R3 is turned off and disconnected from any power source. Close the lid and flip the laptop over to access the bottom panel.
  3. Dell Alienware M11x R3 Battery Replacement: 手順 3、 1の画像 1
    • Caution: Ensure computer is completely powered down before attempting to remove the lower case of the computer.
    • Close the lid and flip the laptop over to access the bottom panel. Unscrew the two circled screws.
  4. Dell Alienware M11x R3 Battery Replacement: 手順 4、 1の画像 1
    • After removing the two screws, gently lift up the battery with the small plastic tab attached.
  5. Dell Alienware M11x R3 Battery Replacement: 手順 5、 1の画像 1
    • Caution: Do not attempt to fully remove the battery while the wire is still connected.
    • Lift the battery out of its casing while allowing the wire to remain attached.
  6. Dell Alienware M11x R3 Battery Replacement: 手順 6、 1の画像 1
    • Behind the battery, locate the PD12 battery wire and gently unplug it.
  7. Dell Alienware M11x R3 Battery Replacement: 手順 7、 1の画像 1
    • With the wire unplugged, and all of the screws taken out, you are free to remove the battery for replacement.
    • Remember to properly dispose of the old battery according to local regulations and recycling guidelines.
終わりに
To reassemble your device, follow these instructions in reverse order using a new battery in place of the old one.
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Richard Maurice
メンバー登録日: 03/08/17
534 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 UMass Dartmouth, Team S3-G7, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S3G7
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 2,085
