この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
In this guide, we will be showing you how to remove and replace the Memory Module.
必要な工具と部品
To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
To remove memory module(s) from connectors DIMM1 and DIMM2: Remove the palm rest. See"Removing the Palm Rest" on page 39.
Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
2 の人々がこのガイドを完成させました。
