メインコンテンツにスキップ
はじめに
In this guide, we will be showing you how to remove and replace the Hard Drive.
パーツ
パーツは指定されていません。
  1. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Disconnect the hard-drive cable from its connector on the system board.
  2. Loosen the captive screws that secure the hard-drive assembly to the computer base.
    • Loosen the captive screws that secure the hard-drive assembly to the computer base.
  3. Using the pull-tab, lift the hard-drive  assembly out of the computer base.
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Disconnect the interposer from the hard drives. NOTE: Your computer supports up to three drives.
    • Disconnect the interposer from the hard drives.
    • NOTE: Your computer supports up to three drives.
  5. Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
    • Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
  6. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  7. Place the NEW primary hard drive  in the hard-drive bracket.
    • Place the NEW primary hard drive in the hard-drive bracket.
  8. If applicable, slide the secondary hard drive into the hard-drive bracket.
    • If applicable, slide the secondary hard drive into the hard-drive bracket.
  9. Replace the screws that secure the primary hard drive to the hard-drive bracket.
    • Replace the screws that secure the primary hard drive to the hard-drive bracket.
  10. If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
    • If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
  11. Connect the interposer to the hard drives.
    • Connect the interposer to the hard drives.
  12. Place the hard-drive assembly in the computer base.
    • Place the hard-drive assembly in the computer base.
  13. Tighten the captive screws that secure  the hard-drive assembly to the computer  base.
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  14. Connect the hard-drive cable to its connector on the system board.
    • Connect the hard-drive cable to its connector on the system board.
ゴール
2 の人々がこのガイドを完成させました。
darrius
メンバー登録日: 2018年03月26日
5,072 ポイント
30のガイドは作成済み
チーム
Informative Technologies Inc. Informative Technologies Inc.人のメンバー
Community
15 メンバー
930のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 98
