メインコンテンツにスキップ
はじめに
In this guide, we will be showing you how to remove and replace the Display Assembly.
パーツ
パーツは指定されていません。
  1. WARNING:   Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin
    • Close the display and turn the computer over.
  2. Remove the screws that secure the display assembly to the computer base.
    • Remove the screws that secure the display assembly to the computer base.
  3. Turn the computer over and open the display.
    • Turn the computer over and open the display.
  4. Disconnect the video-card connector cable from its connector on the system board.
    • Disconnect the video-card connector cable from its connector on the system board.
  5. Pull the pull-tab to disconnect the display cable from its connector on the system board.
    • Pull the pull-tab to disconnect the display cable from its connector on the system board.
  6. Disconnect the LED-logo board cable from its connector on the system board.
    • Disconnect the LED-logo board cable from its connector on the system board.
  7. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  8. Disconnect the antenna cables from the connectors on the Mini-Card. See "Removing the Wireless Mini-Card" on page 105.
  9. Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
    • Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
  10. Remove the screw that secures the routing guides to the computer base.
    • Remove the screw that secures the routing guides to the computer base.
  11. Slide and lift the routing guides off the computer base.
    • Slide and lift the routing guides off the computer base.
  12. Remove the screws, on the display hinges, that secure the display assembly to the computer base.
    • Remove the screws, on the display hinges, that secure the display assembly to the computer base.
  13. Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
    • Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
  14. Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
  15. Place the routing guides on the computer base and replace the screw that secures the routing guides to the computer base.
    • Place the routing guides on the computer base and replace the screw that secures the routing guides to the computer base.
  16. Route the Mini-Card antenna cables through the routing guides on the computer base.
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  17. Connect the Mini-Card antenna cables to the Mini-Card. See"Replacing the Wireless Mini-Card" on page 107.
    • Connect the Mini-Card antenna cables to the Mini-Card. See"Replacing the Wireless Mini-Card" on page 107.
    • Connect the display cable, video-card connector cable, and LED-logo board cable to the respective connectors on the system board.
  18. Close the display and turn the computer over.
  19. Replace the screws that secure the display assembly to the computer base.
    • Replace the screws that secure the display assembly to the computer base.
ゴール
ある他の人がこのガイドを完成しました。
darrius
メンバー登録日: 2018年03月26日
5,072 ポイント
30のガイドは作成済み
チーム
Informative Technologies Inc. Informative Technologies Inc.人のメンバー
Community
15 メンバー
930のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 150
