メインコンテンツにスキップ
Dell Alienware 17 Third Hard-Drive Replacement
必要な工具と部品
  1. Dell Alienware 17 Third Hard-Drive Replacement, Disconnecting the Battery Cable: 手順 1、 1の画像 1
  2. Dell Alienware 17 Third Hard-Drive Replacement, Remove the Screws: 手順 2、 1の画像 1
    • Remove the screws that secure the battery to the computer base.
  3. Dell Alienware 17 Third Hard-Drive Replacement, Releasing the Battery: 手順 3、 2の画像 1 Dell Alienware 17 Third Hard-Drive Replacement, Releasing the Battery: 手順 3、 2の画像 2
    • Using the battery cable, lift and release the battery from the tabs on the computer base.
  4. Dell Alienware 17 Third Hard-Drive Replacement, Opening the Display: 手順 4、 1の画像 1
    • Turn the computer over and open the display.
  5. Dell Alienware 17 Third Hard-Drive Replacement, Grounding the System Board: 手順 5、 1の画像 1
    • Press and hold the power button for five seconds to ground the system board.
  6. Dell Alienware 17 Third Hard-Drive Replacement, Slide the New Battery: 手順 6、 1の画像 1
    • Slide the NEW battery under the tabs on the computer base.
  7. Dell Alienware 17 Third Hard-Drive Replacement, Aligning the Screw Holes: 手順 7、 1の画像 1
    • Align the screw holes on the battery with the screw holes on the computer base.
  8. Dell Alienware 17 Third Hard-Drive Replacement, Replace the Screws: 手順 8、 1の画像 1
    • Replace the screws that secure the battery to the computer base.
  9. Dell Alienware 17 Third Hard-Drive Replacement, Connect the Battery Cable: 手順 9、 1の画像 1
    • Connect the battery cable to the system board.
  10. Dell Alienware 17 Third Hard-Drive Replacement, Remove the Screws: 手順 10、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The media bay can accommodate an optical drive, a hard drive, or a solid-state drive.
    • Remove the screws that secure the tertiary hard drive assembly to the computer base.
  11. Dell Alienware 17 Third Hard-Drive Replacement, Disconnecting the Hard-Drive Cable: 手順 11、 1の画像 1
    • Using the pull-tab, disconnect the hard-drive cable from the system board.
  12. Dell Alienware 17 Third Hard-Drive Replacement, Lifting the Hard-Drive Assembly: 手順 12、 1の画像 1
    • Lift the hard-drive assembly off the computer base.
  13. Dell Alienware 17 Third Hard-Drive Replacement, Disconnect the Interposer: 手順 13、 2の画像 1 Dell Alienware 17 Third Hard-Drive Replacement, Disconnect the Interposer: 手順 13、 2の画像 2
    • Disconnect the interposer from the hard drive.
  14. Dell Alienware 17 Third Hard-Drive Replacement, Remove the Screws: 手順 14、 1の画像 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  15. Dell Alienware 17 Third Hard-Drive Replacement, Lifting the Hard-Drive Bracket: 手順 15、 2の画像 1 Dell Alienware 17 Third Hard-Drive Replacement, Lifting the Hard-Drive Bracket: 手順 15、 2の画像 2
    • Lift the hard-drive bracket off the hard drive.
  16. Dell Alienware 17 Third Hard-Drive Replacement, Align the Screw Holes: 手順 16、 1の画像 1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  17. Dell Alienware 17 Third Hard-Drive Replacement, Replace the Screws: 手順 17、 1の画像 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  18. Dell Alienware 17 Third Hard-Drive Replacement, Connect the Interposer: 手順 18、 1の画像 1
    • Connect the interposer to the hard drive.
  19. Dell Alienware 17 Third Hard-Drive Replacement, Align the Screw Holes: 手順 19、 1の画像 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  20. Dell Alienware 17 Third Hard-Drive Replacement, Replace the Screws: 手順 20、 1の画像 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  21. Dell Alienware 17 Third Hard-Drive Replacement, Connecting the Hard-Drive Cable: 手順 21、 1の画像 1
    • Connect the hard-drive cable to the system board.
終わりに
作成者
2人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
79,522 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 1,168
