はじめに
If you need to replace the Wi-Fi card from your Dell Alienware 15 R3, follow this guide.
必要な工具と部品
Flip the laptop over so that the backside is facing up.
Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
Open the flap to reveal the Wi-Fi card.
Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
Use a spudger to detach the coaxial cables from the Wi-Fi card.
