メインコンテンツにスキップ
Dell Alienware 15 R3 Wi-Fi Card Replacement
必要な工具と部品
  1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: 手順 1、 3の画像 1 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: 手順 1、 3の画像 2 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: 手順 1、 3の画像 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Wi-Fi Card Replacement: 手順 2、 1の画像 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Wi-Fi Card Replacement, Cover Assembly: 手順 3、 1の画像 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Wi-Fi Card Replacement: 手順 4、 2の画像 1 Dell Alienware 15 R3 Wi-Fi Card Replacement: 手順 4、 2の画像 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Wi-Fi Card Replacement: 手順 5、 3の画像 1 Dell Alienware 15 R3 Wi-Fi Card Replacement: 手順 5、 3の画像 2 Dell Alienware 15 R3 Wi-Fi Card Replacement: 手順 5、 3の画像 3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: 手順 6、 3の画像 1 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: 手順 6、 3の画像 2 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: 手順 6、 3の画像 3
    • Open the flap to reveal the Wi-Fi card.
    • Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
    • Use a spudger to detach the coaxial cables from the Wi-Fi card.
    • Be careful when detaching these cable connectors from the Wi-Fi card. The base of the connectors are prone to break off.
終わりに
作成者
2人の作成者と共同で作成されました。
Jake Nelson
メンバー登録日: 09/22/22
581 ポイント
7のガイドは作成済み
チーム
University of North Texas, Team 4-1, Saru Jimmy Fall 2022 University of North Texas, Team 4-1, Saru Jimmy Fall 2022人のメンバー
UNT-SARU JIMMY-F22S4G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 30
今までの合計 338
