メインコンテンツにスキップ
Dell Alienware 15 R3 Speakers Replacement
必要な工具と部品
  1. Dell Alienware 15 R3 Speakers Replacement, Speakers: 手順 1、 1の画像 1
    • Remove the 6 M2.5x13 that are holding the back cover on.
    • Remove the 1 M2x3 at the rear of the device that is holding the back cover on.
    • Gently pry on the sides of the back cover with the iFixit Opening Tool to release the tabs.
    • Remove the cover from the computer.
  2. Dell Alienware 15 R3 Speakers Replacement: 手順 2、 1の画像 1
    • Disconnect the battery.
  3. Dell Alienware 15 R3 Speakers Replacement: 手順 3、 1の画像 1
    • Remove the M2x3 screw holding the wireless card.
    • Lift and slide the wireless card from its slot.
  4. Dell Alienware 15 R3 Speakers Replacement: 手順 4、 3の画像 1 Dell Alienware 15 R3 Speakers Replacement: 手順 4、 3の画像 2 Dell Alienware 15 R3 Speakers Replacement: 手順 4、 3の画像 3
    • Remove the two M2.5x6 screws connecting the rear cover to the computer.
    • Gently pry the rear cover with the iFixit Opening Tool to release the two tabs on each side.
    • Slide the rear cover from the computer.
  5. Dell Alienware 15 R3 Speakers Replacement: 手順 5、 3の画像 1 Dell Alienware 15 R3 Speakers Replacement: 手順 5、 3の画像 2 Dell Alienware 15 R3 Speakers Replacement: 手順 5、 3の画像 3
    • Remove the light cable located between hard drive port and fan.
    • Open the latch and remove the keyboard cable, keyboard backlight cable, and the macro keys cable.
    • Remove the 11 M2.5x8 screws that secure the computer base.
    • Remove the 2 M2x3 screws.
    • Use a pry tool to separate the base from the computer and then lift the computer base from the computer.
  6. Dell Alienware 15 R3 Speakers Replacement: 手順 6、 2の画像 1 Dell Alienware 15 R3 Speakers Replacement: 手順 6、 2の画像 2
    • Remove the M2.5x5 screw holding the battery to the computer.
    • Remove the battery from the computer.
  7. Dell Alienware 15 R3 Speakers Replacement: 手順 7、 2の画像 1 Dell Alienware 15 R3 Speakers Replacement: 手順 7、 2の画像 2
    • Disconnect the speaker cable from the motherboard.
    • Lift the speakers from the computer.
終わりに
作成者
3人の作成者と共同で作成されました。
Andrew M
メンバー登録日: 03/28/23
433 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-4, Harley Spring 2023 IUPUI, Team 2-4, Harley Spring 2023人のメンバー
IUPUI-HARLEY-S23S2G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 194
