はじめに
If you need to install a new SSD or are installing a SSD for the first time for your Dell Alienware 15 R3, this guide will help you.
Before starting this repair, be sure to turn off your laptop and unplug the power cord. To be safe, it is wise to unplug the battery connector from the motherboard too.
必要な工具と部品
Flip the laptop over so that the backside is facing up.
Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
