メインコンテンツにスキップ
Dell Alienware 15 R3 Fan Replacement
必要な工具と部品
  1. Dell Alienware 15 R3 Fan Replacement, Fan: 手順 1、 1の画像 1
    • Remove the 6 M2.5x13mm screws that are holding the back cover on.
    • Remove the 1 M2x3mm at the rear of the device that is holding the back cover on.
    • Gently pry on the sides of the back cover with the iFxit Opening Tool to release tabs.
    • Pull up and backwards to remove the back cover from the computer.
  2. Dell Alienware 15 R3 Fan Replacement: 手順 2、 1の画像 1
    • Disconnect the battery cable located above the hard drive case.
  3. Dell Alienware 15 R3 Fan Replacement: 手順 3、 1の画像 1
    • Unscrew the M2x3mm screw holding down the wireless card.
    • Lift and slide the wireless card from its slot.
  4. Dell Alienware 15 R3 Fan Replacement: 手順 4、 3の画像 1 Dell Alienware 15 R3 Fan Replacement: 手順 4、 3の画像 2 Dell Alienware 15 R3 Fan Replacement: 手順 4、 3の画像 3
    • Remove the two M2.5x6mm screws connecting the rear cover to the computer.
    • Gently pry the rear cover with the iFixit Opening Tool to release the tabs 2 tabs on each side.
    • Slide the rear cover off of the computer.
  5. Dell Alienware 15 R3 Fan Replacement: 手順 5、 3の画像 1 Dell Alienware 15 R3 Fan Replacement: 手順 5、 3の画像 2 Dell Alienware 15 R3 Fan Replacement: 手順 5、 3の画像 3
    • Remove light cable between the hard drive port and the fan.
    • Lift the latches and remove the keyboard cable, keyboard backlight cable, and the macro keys cable.
    • Remove the 11 M2.5x8mm screws that secure the computer base.
    • Remove the 2 M2x3mm screws.
    • Lift the computer base from the computer. Use the iFixit Opening tool to pry the base off the computer. Should separate with ease be carful not to break it.
  6. Dell Alienware 15 R3 Fan Replacement: 手順 6、 1の画像 1
    • In the sequential order that is indicated on the cooler assembly, remove the 7 M2x3mm screws securing the cooler assembly to the system board.
    • Disconnect the left and right fan cables from the system board.
    • Lift to remove the cooler assembly from the computer.
終わりに
作成者
4人の作成者と共同で作成されました。
Andrew M
メンバー登録日: 03/28/23
433 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-4, Harley Spring 2023 IUPUI, Team 2-4, Harley Spring 2023人のメンバー
IUPUI-HARLEY-S23S2G4
3 メンバー
3のガイドは作成済み
2 件のコメント
WARNING: This guide is missing many, many steps. You will have to completely remove the motherboard to disconnect the fan power cables. You will also need to clean the CPU and GPU and apply new thermal paste.
William Geraghty - 返信
Also had to remove any NVMe drives to get the full backplate off and the HDD just to remove the weight from the backplate before prying it off.
Patrick Harrison - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 86
今までの合計 1,035
