メインコンテンツにスキップ
Dell Alienware 15 R3 Battery Replacement
必要な工具と部品
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: 手順 1、 3の画像 1 Dell Alienware 15 R3 Battery Replacement, Back Case: 手順 1、 3の画像 2 Dell Alienware 15 R3 Battery Replacement, Back Case: 手順 1、 3の画像 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Battery Replacement: 手順 2、 1の画像 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: 手順 3、 1の画像 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Battery Replacement: 手順 4、 2の画像 1 Dell Alienware 15 R3 Battery Replacement: 手順 4、 2の画像 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Battery Replacement: 手順 5、 3の画像 1 Dell Alienware 15 R3 Battery Replacement: 手順 5、 3の画像 2 Dell Alienware 15 R3 Battery Replacement: 手順 5、 3の画像 3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Battery Replacement, Battery: 手順 6、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
  7. Dell Alienware 15 R3 Battery Replacement: 手順 7、 3の画像 1 Dell Alienware 15 R3 Battery Replacement: 手順 7、 3の画像 2 Dell Alienware 15 R3 Battery Replacement: 手順 7、 3の画像 3
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jake Nelson
メンバー登録日: 09/22/22
581 ポイント
7のガイドは作成済み
チーム
University of North Texas, Team 4-1, Saru Jimmy Fall 2022 University of North Texas, Team 4-1, Saru Jimmy Fall 2022人のメンバー
UNT-SARU JIMMY-F22S4G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 73
過去 30 日: 282
今までの合計 5,456
