メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Alienware 15 Memory Module Replacement
必要な工具と部品
    • After turning the computer off, close the display and turn the computer over.
    FixBotに聞いてみる
    コメントを追加
  1. Dell Alienware 15 Memory Module Replacement, Remove the Back Panel Screws and Lift: 手順 2、 1の画像 1
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
    FixBotに聞いてみる
    コメントを追加
  2. Dell Alienware 15 Memory Module Replacement, Optional: Disconnect the Battery: 手順 3、 1の画像 1
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
    FixBotに聞いてみる
    コメントを追加
  3. Dell Alienware 15 Memory Module Replacement, Memory Securing Clips: 手順 4、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
    FixBotに聞いてみる
    コメントを追加
  4. Dell Alienware 15 Memory Module Replacement, Remove Memory Module: 手順 5、 1の画像 1
    • Slide and remove the memory module from any memory-module slots that you would like to repopulate.
    FixBotに聞いてみる
    コメントを追加
  5. Dell Alienware 15 Memory Module Replacement, Adding New Memory Module: 手順 6、 1の画像 1
    • Align the notch on the New memory module with the tab on the memory- module slot.
    FixBotに聞いてみる
    コメントを追加
  6. Dell Alienware 15 Memory Module Replacement, Firmly Press the Memory Module Down.: 手順 7、 1の画像 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place. Do this individually for each memory module that is replaced.
    • NOTE : If you do not hear the click, remove the memory module and reinstall it.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, screw the base panel on again.
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
46,149 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
45 メンバー
2,002のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 52
今までの合計 906
