メインコンテンツにスキップ
Dell Alienware 15 Hard Drive Replacement
必要な工具と部品
    • After turning the computer off, close the display and turn the computer over.
  1. Dell Alienware 15 Hard Drive Replacement, Remove the Back Panel Screws and Lift: 手順 2、 1の画像 1
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
  2. Dell Alienware 15 Hard Drive Replacement, Optional: Disconnect the Battery: 手順 3、 1の画像 1
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
  3. Dell Alienware 15 Hard Drive Replacement, Remove Cables: 手順 4、 1の画像 1
    • CAUTION : Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION : To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • Remove the keyboard-backlight cable, keyboard cable, and macro-keys cable from the routing guides on the computer base. You do not need to unlatch these cables from their connectors.
  4. Dell Alienware 15 Hard Drive Replacement, Remove Hard Drive Assembly Screws: 手順 5、 1の画像 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  5. Dell Alienware 15 Hard Drive Replacement, Disconnect Hard Drive: 手順 6、 1の画像 1
    • Using the pull tab, disconnect the hard-drive cable from the system board.
    • Note the hard-drive cable routing and remove the cable from the routing guides on the computer base.
  6. Dell Alienware 15 Hard Drive Replacement, Remove Hard Drive: 手順 7、 1の画像 1
    • Lift and slide the hard-drive assembly off the computer base.
  7. Dell Alienware 15 Hard Drive Replacement, Remove Hard Drive From Assembly: 手順 8、 1の画像 1
    • Remove the screws that secure the hard-drive bracket to the hard-drive assembly.
  8. Dell Alienware 15 Hard Drive Replacement, Lift the Hard Drive off the Bracket: 手順 9、 1の画像 1
    • Lift the hard-drive bracket off the hard-drive assembly.
  9. Dell Alienware 15 Hard Drive Replacement, Disconnect Hard Drive From interposer: 手順 10、 1の画像 1
    • Disconnect the interposer from the hard drive.
  10. Dell Alienware 15 Hard Drive Replacement, Connect Interposer to Replacement Drive: 手順 11、 1の画像 1
    • Connect the interposer to the new hard drive. The new drive must be a 2.5 inch hard drive.
  11. Dell Alienware 15 Hard Drive Replacement, Align Hard Drive With Screw Holes: 手順 12、 1の画像 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  12. Dell Alienware 15 Hard Drive Replacement, Replace Screws: 手順 13、 1の画像 1
    • Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
  13. Dell Alienware 15 Hard Drive Replacement, Slide Hard Drive Assembly Into Computer Base: 手順 14、 1の画像 1
    • Slide the hard-drive assembly under the tab on the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  14. Dell Alienware 15 Hard Drive Replacement, Secure the Hard Drive Assembly: 手順 15、 1の画像 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  15. Dell Alienware 15 Hard Drive Replacement, Route and Connect The Hard Drive Cable: 手順 16、 1の画像 1
    • Route the hard-drive cable through the routing guides on the computer base.
    • Connect the hard-drive cable to the system board.
  16. Dell Alienware 15 Hard Drive Replacement, Route and Connect Keyboard Cables: 手順 17、 1の画像 1
    • Route the keyboard-backlight cable, keyboard cable, and macro-keys cable back through their routing guides on the computer base.
終わりに
If you have followed all these instructions, then your hard drive should be reinstalled!
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
44,830 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 36
過去 30 日: 58
今までの合計 3,203
