はじめに
In this guide, we will show you how to remove and replace the Display Panel.
必要な工具と部品
Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
Disconnect the battery cable from the system-board connector.
Using the battery cable, lift the battery and release it from the tabs on the computer base.
Press and hold the power button for five seconds to ground the system board.
Align the screw holes on the battery with the screw holes on the computer base.
Remove the screws that secure the secondary hard-drive assembly to the computer base.
Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
Remove the screw that secures the secondary hard-drive assembly to the main bracket.
Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
Disconnect the interposer from the secondary hard-drive connector.
Place the NEW secondary hard-drive in the secondary hard-drive bracket.
Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
Replace the screw that secures the secondary hard-drive assembly to the main bracket.
Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
Replace the screws that secure the secondary hard-drive assembly to the computer base.
Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
Remove the screws that secure the palm -rest assembly to the computer base.
Using a plastic scribe, pry the palm-rest assembly from the computer base.
Release the connector latches to disconnect the flexi-cable from the system board.
Follow the instructions from step 1 to step 9 in Removing the Keyboard.
Follow the instructions from step 1 to step 4 in Removing the Status-Light Board.
Follow the instructions from step 1 to step 4 in Removing the Speakers.
Follow the instructions from step 1 to step 4 in Removing the Power-Button Board.
Follow the instructions from step 1 to step 4 in Replacing the Power-Button Board.
Follow the instructions from step 1 to step 3 in Replacing the Speakers.
Follow the instructions from step 1 to step 8 in Replacing the Keyboard.
Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
Replace the screws that secure the palm-rest assembly to the computer base.
Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
Disconnect the display and camera cables from the system-board connectors.
Remove the display, camera, and antenna cables from the slots on the computer base.
Note the display, camera and antenna cable-routing and remove the cables from their routing guides.
Align the screw holes on the NEW display assembly with the screw holes on the computer base.
Replace the screws that secure the display assembly to the computer base.
Using your fingertips, carefully pry up the inside edge of the display bezel
Align the NEW display bezel with the display back-cover, and gently snap the display bezel into place.
Remove the screws that secure the display hinges to the display back-cover.
Align the screw holes on the NEW display hinges with the screw holes on the display back-cover.
Replace the screws that secure the display hinges to the display back-cover.
Remove the screws that secure the display panel to the display back-cover.
Carefully turn the display panel over and place it on the display back-cover.
Peel the tape that secures the display cable to the display-panel connector.
Lift the connector latch and disconnect the display cable from the display-panel connector.
Connect the display cable to the display-panel connector and press down on the connector latch to secure the cable.
Carefully rotate the NEW display panel and align the screw holes on the display panel with the screw holes on the display back-cover.
Replace the screws that secure the display panel to the display back-cover.
