メインコンテンツにスキップ
Dell Alienware 13 Touch pad Replacement
必要な工具と部品
  1. Dell Alienware 13 Touch pad Replacement, Base Panel: 手順 1、 1の画像 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Touch pad Replacement: 手順 2、 1の画像 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Touch pad Replacement: 手順 3、 3の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 3、 3の画像 2 Dell Alienware 13 Touch pad Replacement: 手順 3、 3の画像 3
    • Remove the small access panel using a heavy duty spudger.
  4. Dell Alienware 13 Touch pad Replacement, Touch pad: 手順 4、 2の画像 1 Dell Alienware 13 Touch pad Replacement, Touch pad: 手順 4、 2の画像 2
    • Disconnect the battery cable from the battery cable terminal.
  5. Dell Alienware 13 Touch pad Replacement: 手順 5、 1の画像 1
    • Remove (4) 6 mm Phillips head screws from the solid-state metal drive bracket, using a Phillips # 1 screwdriver.
  6. Dell Alienware 13 Touch pad Replacement: 手順 6、 2の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 6、 2の画像 2
    • Grab the pull tab to pivot the solid-state drive bracket upwards. Remove the bracket from the computer base.
  7. Dell Alienware 13 Touch pad Replacement: 手順 7、 2の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 7、 2の画像 2
    • Using the pull tab, disconnect the black solid-state drive cable from the system board.
  8. Dell Alienware 13 Touch pad Replacement: 手順 8、 1の画像 1
    • Remove (2) 3 mm Phillips head screws, using a Phillips # 0 screwdriver, that connect the solid-state drive assembly to the computer base.
  9. Dell Alienware 13 Touch pad Replacement: 手順 9、 2の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 9、 2の画像 2
    • Lift up on the solid-state drive assembly to remove it from the computer base.
  10. Dell Alienware 13 Touch pad Replacement: 手順 10、 2の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 10、 2の画像 2
    • Locate two cables labeled, "KB Backlight" (orange) and "KB Membrane" (black). Lift up on the latches to disconnect the cables from the system board.
  11. Dell Alienware 13 Touch pad Replacement: 手順 11、 3の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 11、 3の画像 2 Dell Alienware 13 Touch pad Replacement: 手順 11、 3の画像 3
    • Remove (8) 9 mm Phillips head screws using a Phillips # 1 screwdriver, that secures the palm-rest assembly to the computer base.
    • Remove (4) 8 mm Phillips head screws using a Phillips # 1 screwdriver.
    • Remove (2) 7 mm Phillips head screws using a Phillips # 1 screwdriver.
  12. Dell Alienware 13 Touch pad Replacement: 手順 12、 2の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 12、 2の画像 2
    • Lift the computer base slightly towards you and push the release tabs on the palm-rest assembly until it pops out using a spudger.
  13. Dell Alienware 13 Touch pad Replacement: 手順 13、 3の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 13、 3の画像 2 Dell Alienware 13 Touch pad Replacement: 手順 13、 3の画像 3
    • Turn the computer over and open the display as far as possible.
    • Using a plastic spudger, pry up along the edges of the palm-rest assembly.
    • Gently lift the palm-rest assembly.
  14. Dell Alienware 13 Touch pad Replacement: 手順 14、 3の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 14、 3の画像 2 Dell Alienware 13 Touch pad Replacement: 手順 14、 3の画像 3
    • Lift the connector latch and disconnect the power-button board cable from the system board. Identified as a cable with a blue tab.
    • Lift the palm-rest assembly off the computer base.
  15. Dell Alienware 13 Touch pad Replacement: 手順 15、 2の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 15、 2の画像 2
    • Disconnect the touch pad cable from the touch pad.
  16. Dell Alienware 13 Touch pad Replacement: 手順 16、 3の画像 1 Dell Alienware 13 Touch pad Replacement: 手順 16、 3の画像 2 Dell Alienware 13 Touch pad Replacement: 手順 16、 3の画像 3
    • Remove (4) 3 mm Phillips head screws securing the touch pad to the palm rest assembly using a Phillips # 0 screwdriver.
    • Lift up and remove the touch pad from the palm rest assembly.
終わりに
作成者
3人の作成者と共同で作成されました。
Adam Russell
メンバー登録日: 09/26/16
898 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 14-2, Eyestone Fall 2016 USF Tampa, Team 14-2, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S14G2
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 308
