メインコンテンツにスキップ
Dell Alienware 13 Status-Light Board Replacement
必要な工具と部品
  1. Dell Alienware 13 Status-Light Board Replacement, Base Panel: 手順 1、 1の画像 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Status-Light Board Replacement: 手順 2、 1の画像 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Status-Light Board Replacement: 手順 3、 3の画像 1 Dell Alienware 13 Status-Light Board Replacement: 手順 3、 3の画像 2 Dell Alienware 13 Status-Light Board Replacement: 手順 3、 3の画像 3
    • Remove the small access panel using a heavy duty spudger.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  4. Dell Alienware 13 Status-Light Board Replacement, Pull Tab: 手順 5、 1の画像 1
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  5. Dell Alienware 13 Status-Light Board Replacement, Disconnecting the State Drive: 手順 6、 1の画像 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  6. Dell Alienware 13 Status-Light Board Replacement, Remove Screws: 手順 7、 1の画像 1
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  7. Dell Alienware 13 Status-Light Board Replacement, Solid-State Drive Assembly Lift: 手順 8、 2の画像 1 Dell Alienware 13 Status-Light Board Replacement, Solid-State Drive Assembly Lift: 手順 8、 2の画像 2
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  8. Dell Alienware 13 Status-Light Board Replacement, Slide and Lift: 手順 9、 1の画像 1
    • Slide and lift the solid-state drive off the solid-state assembly.
  9. Dell Alienware 13 Status-Light Board Replacement, Replacing the Solid-State Drive: 手順 10、 1の画像 1
    • Slide the new solid-state drive into the solid-state drive assembly.
  10. Dell Alienware 13 Status-Light Board Replacement, Replace the Screw: 手順 11、 1の画像 1
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  11. Dell Alienware 13 Status-Light Board Replacement, Screw Align: 手順 12、 1の画像 1
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  12. Dell Alienware 13 Status-Light Board Replacement, Screw Replacement: 手順 13、 1の画像 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  13. Dell Alienware 13 Status-Light Board Replacement, Connecting the Drive: 手順 14、 1の画像 1
    • Connect the solid-state drive cable to the system board.
  14. Dell Alienware 13 Status-Light Board Replacement, Aligning Screws: 手順 15、 1の画像 1
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  15. Dell Alienware 13 Status-Light Board Replacement, Replacing Screws: 手順 16、 1の画像 1
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  16. Dell Alienware 13 Status-Light Board Replacement, Disconnecting the Keyboard: 手順 17、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
  17. Dell Alienware 13 Status-Light Board Replacement, Removing the Screws: 手順 18、 2の画像 1 Dell Alienware 13 Status-Light Board Replacement, Removing the Screws: 手順 18、 2の画像 2
    • Remove the screws that secure the palm-rest assembly to the computer base.
  18. Dell Alienware 13 Status-Light Board Replacement, Popping out the Palm-Rest Assembly: 手順 19、 1の画像 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
  19. Dell Alienware 13 Status-Light Board Replacement, Turn the Computer Over: 手順 20、 1の画像 1
    • Turn the computer over and open the display as far as possible.
  20. Dell Alienware 13 Status-Light Board Replacement, Prying the Edges: 手順 21、 1の画像 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  21. Dell Alienware 13 Status-Light Board Replacement, Lifting the Palm-Rest Assembly: 手順 22、 1の画像 1
    • Gently lift the palm-rest assembly and turn it over.
  22. Dell Alienware 13 Status-Light Board Replacement, Disconnecting the Power-Board Cable: 手順 23、 2の画像 1 Dell Alienware 13 Status-Light Board Replacement, Disconnecting the Power-Board Cable: 手順 23、 2の画像 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
    • Remove the Keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
  23. Dell Alienware 13 Status-Light Board Replacement, Connecting the Power-Button Board Cable: 手順 26、 1の画像 1
    • Connect the power-button board cable to the system board.
  24. Dell Alienware 13 Status-Light Board Replacement, Aligning the Palm-Rest Assembly.: 手順 27、 1の画像 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Close the display and turn the computer over.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  25. Dell Alienware 13 Status-Light Board Replacement, Disconnecting the Touchpad Cable: 手順 31、 3の画像 1 Dell Alienware 13 Status-Light Board Replacement, Disconnecting the Touchpad Cable: 手順 31、 3の画像 2 Dell Alienware 13 Status-Light Board Replacement, Disconnecting the Touchpad Cable: 手順 31、 3の画像 3
    • Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
  26. Dell Alienware 13 Status-Light Board Replacement, Peeling the Cables: 手順 32、 1の画像 1
    • Peel the touchpad cable and status-light cable off the keyboard bracket.
  27. Dell Alienware 13 Status-Light Board Replacement, Removing the Keyboard Bracket: 手順 33、 1の画像 1
    • Lift the keyboard bracket off the palm-rest assembly.
  28. Dell Alienware 13 Status-Light Board Replacement, Remove the Screws: 手順 34、 1の画像 1
    • Remove the screws that secure the keyboard to the palm-rest assembly.
  29. Dell Alienware 13 Status-Light Board Replacement, Lifting the Keyboard: 手順 35、 1の画像 1
    • Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
  30. Dell Alienware 13 Status-Light Board Replacement, Aligning the Screw Holes: 手順 36、 1の画像 1
    • Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
  31. Dell Alienware 13 Status-Light Board Replacement, Replacing Screws: 手順 37、 1の画像 1
    • Replace the screws that secure the keyboard to the palm-rest assembly.
    • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
  32. Dell Alienware 13 Status-Light Board Replacement, Replace the Screws: 手順 39、 1の画像 1
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
  33. Dell Alienware 13 Status-Light Board Replacement, Adhering the Cables: 手順 40、 2の画像 1 Dell Alienware 13 Status-Light Board Replacement, Adhering the Cables: 手順 40、 2の画像 2
    • Adhere the touchpad cable and status-light cable to the keyboard bracket.
  34. Dell Alienware 13 Status-Light Board Replacement, Sliding the Cables: 手順 41、 1の画像 1
    • Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
  35. Dell Alienware 13 Status-Light Board Replacement, Disconnecting the Status-Light Board: 手順 42、 2の画像 1 Dell Alienware 13 Status-Light Board Replacement, Disconnecting the Status-Light Board: 手順 42、 2の画像 2
    • Lift the connector latch and disconnect the status-light board cable from the status-light board.
  36. Dell Alienware 13 Status-Light Board Replacement, Remove the Screw: 手順 43、 2の画像 1 Dell Alienware 13 Status-Light Board Replacement, Remove the Screw: 手順 43、 2の画像 2
    • Remove the screw that secures the status-light board to the palm-rest assembly.
  37. Dell Alienware 13 Status-Light Board Replacement, Removing the Status-Light Board: 手順 44、 1の画像 1
    • Lift the status-light board off the palm-rest assembly.
  38. Dell Alienware 13 Status-Light Board Replacement, Securing the Cable: 手順 45、 1の画像 1
    • Slide the NEW status-light board cable into the status-light board connector and press down the latch to secure the cable.
    • Align the screw hole on the status-light board with the screw hole on the palm-rest assembly.
  39. Dell Alienware 13 Status-Light Board Replacement, Replace the Screw: 手順 47、 1の画像 1
    • Replace the screw that secures the status-light board to the palm-rest assembly.
終わりに
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,121 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 111
