メインコンテンツにスキップ
Dell Alienware 13 Solid-State Drive (SSD) Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  1. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Pull Tab: 手順 2、 1の画像 1
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  2. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Disconnecting the State Drive: 手順 3、 1の画像 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  3. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Remove Screws: 手順 4、 1の画像 1
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  4. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Solid-State Drive Assembly Lift: 手順 5、 2の画像 1 Dell Alienware 13 Solid-State Drive (SSD) Replacement, Solid-State Drive Assembly Lift: 手順 5、 2の画像 2
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  5. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Slide and Lift: 手順 6、 1の画像 1
    • Slide and lift the solid-state drive off the solid-state assembly.
  6. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replacing the Solid-State Drive: 手順 7、 1の画像 1
    • Slide the new solid-state drive into the solid-state drive assembly.
  7. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replace the Screw: 手順 8、 1の画像 1
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  8. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Screw Align: 手順 9、 1の画像 1
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  9. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Screw Replacement: 手順 10、 1の画像 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  10. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Connecting the Drive: 手順 11、 1の画像 1
    • Connect the solid-state drive cable to the system board.
  11. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Aligning Screws: 手順 12、 1の画像 1
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  12. Dell Alienware 13 Solid-State Drive (SSD) Replacement, Replacing Screws: 手順 13、 1の画像 1
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
ゴール
作成者
3人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
79,031 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,985のガイドは作成済み
コメント 1 件
Hi there. Could I have a link to the full service manual you got this from? Thanks.
Aiden - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 189
