メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Alienware 13 R3 Computer Base Replacement
必要な工具と部品
  1. Dell Alienware 13 R3 Computer Base Replacement, Loosen the Screws: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
    FixBotに聞いてみる
  2. Dell Alienware 13 R3 Computer Base Replacement, Pry the Base Cover: 手順 2、 1の画像 1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
    FixBotに聞いてみる
  3. Dell Alienware 13 R3 Computer Base Replacement, Lift the Base Cover: 手順 3、 1の画像 1
    • Lift the base cover off the computer base.
    FixBotに聞いてみる
  4. Dell Alienware 13 R3 Computer Base Replacement, Disconnect the Battery Cable: 手順 4、 1の画像 1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    FixBotに聞いてみる
    • Press and hold the power button for five seconds to ground the system board.
    FixBotに聞いてみる
    • Connect the battery cable to the system board.
    FixBotに聞いてみる
  5. Dell Alienware 13 R3 Computer Base Replacement, Slide the Tabs: 手順 7、 1の画像 1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
    FixBotに聞いてみる
  6. Dell Alienware 13 R3 Computer Base Replacement, Tighten the Five Captive Screws: 手順 8、 1の画像 1
    • Tighten the five captive screws that secure the base cover to the computer base.
    FixBotに聞いてみる
  7. Dell Alienware 13 R3 Computer Base Replacement, Remove the Screw: 手順 9、 1の画像 1
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
    FixBotに聞いてみる
  8. Dell Alienware 13 R3 Computer Base Replacement, Lift and Slide the Solid-State Drive: 手順 10、 1の画像 1
    • Lift and slide the solid-state drive from the solid-state drive slot.
    FixBotに聞いてみる
    • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
    FixBotに聞いてみる
  9. Dell Alienware 13 R3 Computer Base Replacement, Press the Memory Module: 手順 12、 1の画像 1
    • Press the memory module down until it clicks into place.
    FixBotに聞いてみる
  10. Dell Alienware 13 R3 Computer Base Replacement, Remove the Screws: 手順 13、 1の画像 1
    • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
    FixBotに聞いてみる
  11. Dell Alienware 13 R3 Computer Base Replacement, Using a Plastic Scribe: 手順 14、 1の画像 1
    • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
    FixBotに聞いてみる
    • Slide and remove the rear-I/O cover from the computer base.
    FixBotに聞いてみる
  12. Dell Alienware 13 R3 Computer Base Replacement, Sliding the Rear-I/O: 手順 16、 1の画像 1
    • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
    FixBotに聞いてみる
    • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
    FixBotに聞いてみる
  13. Dell Alienware 13 R3 Computer Base Replacement, Remove the Screws: 手順 18、 1の画像 1
    • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    FixBotに聞いてみる
  14. Dell Alienware 13 R3 Computer Base Replacement, Remove the Screw: 手順 19、 1の画像 1
    • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
    FixBotに聞いてみる
  15. Dell Alienware 13 R3 Computer Base Replacement, Remove the Two Screws: 手順 20、 1の画像 1
    • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    FixBotに聞いてみる
  16. Dell Alienware 13 R3 Computer Base Replacement, Lift the Computer Base: 手順 21、 1の画像 1
    • Lift the computer base from the palm-rest assembly.
    FixBotに聞いてみる
  17. Dell Alienware 13 R3 Computer Base Replacement, Align the Screw Holes: 手順 22、 1の画像 1
    • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
    FixBotに聞いてみる
    • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    FixBotに聞いてみる
    • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
    FixBotに聞いてみる
    • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    FixBotに聞いてみる
終わりに
作成者
2人の作成者と共同で作成されました。
Terrence15
メンバー登録日: 12/18/17
80,125 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
45 メンバー
2,002のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 63
今までの合計 914
