メインコンテンツにスキップ
Dell Alienware 13 Palm Rest Replacement
必要な工具と部品
  1. Dell Alienware 13 Palm Rest Replacement, Base Panel: 手順 1、 1の画像 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Palm Rest Replacement: 手順 2、 1の画像 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Palm Rest Replacement: 手順 3、 3の画像 1 Dell Alienware 13 Palm Rest Replacement: 手順 3、 3の画像 2 Dell Alienware 13 Palm Rest Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Spudger
  4. Dell Alienware 13 Palm Rest Replacement, Disconnecting the Keyboard: 手順 4、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
  5. Dell Alienware 13 Palm Rest Replacement, Removing the Screws: 手順 5、 2の画像 1 Dell Alienware 13 Palm Rest Replacement, Removing the Screws: 手順 5、 2の画像 2
    • Remove the screws that secure the palm-rest assembly to the computer base.
  6. Dell Alienware 13 Palm Rest Replacement, Popping out the Palm-Rest Assembly: 手順 6、 1の画像 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
  7. Dell Alienware 13 Palm Rest Replacement, Turn the Computer Over: 手順 7、 1の画像 1
    • Turn the computer over and open the display as far as possible.
  8. Dell Alienware 13 Palm Rest Replacement, Prying the Edges: 手順 8、 1の画像 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  9. Dell Alienware 13 Palm Rest Replacement, Lifting the Palm-Rest Assembly: 手順 9、 1の画像 1
    • Gently lift the palm-rest assembly and turn it over.
  10. Dell Alienware 13 Palm Rest Replacement, Disconnecting the Power-Board Cable: 手順 10、 2の画像 1 Dell Alienware 13 Palm Rest Replacement, Disconnecting the Power-Board Cable: 手順 10、 2の画像 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
    • Remove the Keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
  11. Dell Alienware 13 Palm Rest Replacement, Connecting the Power-Button Board Cable: 手順 13、 1の画像 1
    • Connect the power-button board cable to the system board.
  12. Dell Alienware 13 Palm Rest Replacement, Aligning the Palm-Rest Assembly.: 手順 14、 1の画像 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Close the display and turn the computer over.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
終わりに
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,858 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,994のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 355
