はじめに
We will be removing the Palm Rest panel from the computer which will allow us to access the internals of the computer.
必要な工具と部品
手順1 Removal of the Laptop Battery
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Then turn the laptop around on its back.
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
Disconnect the function key cable from the connector on the system board.
Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
ある他の人がこのガイドを完成しました。
