はじめに
You will be removing the memory module from the laptop, along with some of the precursors before doing that.
必要な工具と部品
手順1 Removal of the Laptop Battery
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Then turn the laptop around on its back.
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
手順3 Removing the back
注意: 手順 3-9 は、作業進行中としてマークされている ガイド から引用されています。
Turn the computer around and remove the eighteen screws on the base cover.
Disconnect the function key cable from the connector on the system board.
Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the memory module connector.
Align the notch in the memory module with the tab in the memory module connector.
Slide the module firmly into the slot at a 45-degree angle, and press the other end of the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
Put back the palm rest assembly.
Then put the computer battery back within the computer.
Turn on the computer. As the computer boots, it detects the memory and automatically updates the system configuration information.To confirm the amount of memory installed in the computer, Click Start ®Control Panel®System and Security®System.
