この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
We will replace the laptop battery after removing the old battery.
手順1 Removal of the Laptop Battery
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Then turn the laptop around on its back.
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
Align the battery with the battery slot before rotating it in place. There will be a snap.
The battery will already be within the laptop, so no further steps needed.
ある他の人がこのガイドを完成しました。
