はじめに
We will be removing and replacing the coin battery within the Dell Adamo XPS laptop.
必要な工具と部品
手順1 Removal of the Laptop Battery
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Then turn the laptop around on its back.
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
手順3 Removing the back
注意: 手順 3-9 は、作業進行中としてマークされている ガイド から引用されています。
Turn the computer around and remove the eighteen screws on the base cover.
Disconnect the function key cable from the connector on the system board.
Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
Locate the coin-cell battery, which is similar to a battery used on watches.
Then disconnect the coin-cell battery cable from the connector on the system board.
Using the spudger carefully use it to pry out the battery from the board.
Using the new coin-cell battery with adhesive to adhere it to the system board.
Then reconnect the coin-cell battery cable to the connector on the system board.
To reassemble the laptop do the steps for the palm rest panel backwards. Then the removal of the battery backwards to completely close off the laptop.
