必要な工具と部品
手順1 Removal of the Laptop Battery
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Then turn the laptop around on its back.
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
手順3 Removing the back
注意: 手順 3-9 は、作業進行中としてマークされている ガイド から引用されています。
Turn the computer around and remove the eighteen screws on the base cover.
Disconnect the function key cable from the connector on the system board.
Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
After removing the laptop battery and the pal rest panel.
Disconnect the bridge battery cable from the connector on the left daughter board.
The bridge battery is glued to the base cover. Use the spudger to pry the bridge battery out of the base cover.
Use adhesive on the bridge battery to ahere it to the base cover.
Reconnect the bridge battery cable to the connector on the left daughter board.
