メインコンテンツにスキップ
Dell AC511 Rear Panel Replacement
必要な工具と部品
  1. Dell AC511 Rear Panel Replacement, Front Panel: 手順 1、 3の画像 1 Dell AC511 Rear Panel Replacement, Front Panel: 手順 1、 3の画像 2 Dell AC511 Rear Panel Replacement, Front Panel: 手順 1、 3の画像 3
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Rear Panel Replacement: 手順 2、 2の画像 1 Dell AC511 Rear Panel Replacement: 手順 2、 2の画像 2
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Rear Panel Replacement: 手順 3、 2の画像 1 Dell AC511 Rear Panel Replacement: 手順 3、 2の画像 2
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Rear Panel Replacement, Speaker: 手順 4、 2の画像 1 Dell AC511 Rear Panel Replacement, Speaker: 手順 4、 2の画像 2
    • Follow the three wires connected to the speaker to find where they connect to the circuit board.
    • Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
  5. Dell AC511 Rear Panel Replacement, Volume Knob: 手順 5、 1の画像 1
    • Apply a light downward pressure on the circuit board next to the volume control.
    • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
  6. Dell AC511 Rear Panel Replacement: 手順 6、 1の画像 1
    • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
    • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
  7. Dell AC511 Rear Panel Replacement, Rear Panel: 手順 7、 1の画像 1
    • Use the pointy end of the spudger to push the audio jack ports into the device to disconnect the secondary circuit board from the rear ranel.
    • Do not use too much force. Pushing too hard will risk breaking the audio jacks.
  8. Dell AC511 Rear Panel Replacement: 手順 8、 2の画像 1 Dell AC511 Rear Panel Replacement: 手順 8、 2の画像 2
    • Remove the 10 mm bolt using a socket wrench with a 10-11 mm socket.
    • After removing the bolt, pull the disconnected volume control board out.
終わりに
作成者
2人の作成者と共同で作成されました。
William Cook
メンバー登録日: 03/19/24
617 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024人のメンバー
UMASSD-SHADDIX-S24S4G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 14
今までの合計 107
