メインコンテンツにスキップ
Definitive Technology W7 Motherboard Replacement
必要な工具と部品
  1. Definitive Technology W7 Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Definitive Technology W7 Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Definitive Technology W7 Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
    • The screw next to the I/O panel will be approximately 20 mm in length. The other screws will be approximately 35 mm in length.
    • Use the metal spudger to remove all rubber feet.
    • Unscrew all four screws from under the rubber feet.
    • These screws will be approximately 35 mm in length.
    • You can now use the prying tool to pry the bottom panel off the speaker.
  2. Definitive Technology W7 Motherboard Replacement: 手順 2、 1の画像 1
    • Using a Phillips #2 screwdriver, remove the 5 screws from the motherboard.
    • These screws are approximately 8 mm in length.
  3. Definitive Technology W7 Motherboard Replacement: 手順 3、 2の画像 1 Definitive Technology W7 Motherboard Replacement: 手順 3、 2の画像 2
    • Push up the locking tabs on the sides of the ribbon cable connector.
    • Gently pull the ribbon cable out from the connector to remove it.
  4. Definitive Technology W7 Motherboard Replacement: 手順 4、 2の画像 1 Definitive Technology W7 Motherboard Replacement: 手順 4、 2の画像 2
    • Tilt the motherboard outwards from the speaker.
    • Remove all five connectors from the motherboard.
    • Remove the motherboard from the speaker.
  5. Definitive Technology W7 Motherboard Replacement: 手順 5、 2の画像 1 Definitive Technology W7 Motherboard Replacement: 手順 5、 2の画像 2
    • Using the Phillips #2 screwdriver, remove the three screws from the network card.
    • These screws are approximately 8mm in length.
    • Remove the network card from the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Magnus Maillet
メンバー登録日: 10/26/22
171 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-5, Petersen Fall 2022 UMass Dartmouth, Team 2-5, Petersen Fall 2022人のメンバー
UMASSD-PETERSEN-F22S2G5
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 19
今までの合計 573
