メインコンテンツにスキップ
DeWalt DW997 Trigger Replacement
必要な工具と部品
  1. DeWalt DW997 Trigger Replacement, Trigger: 手順 1、 2の画像 1 DeWalt DW997 Trigger Replacement, Trigger: 手順 1、 2の画像 2
    • First remove the seven 21mm screws using a Torx T15 screw bit.
    • Then use a Torx T10 screw bit to remove the remaining 18mm screw.
    • After removing all of the screws, lift the cover off.
    • Do not attempt to pry the covers apart; doing so can cause the covers to crack.
  2. DeWalt DW997 Trigger Replacement: 手順 2、 1の画像 1
    • Carefully remove the trigger pack by lifting the pack straight up.
  3. DeWalt DW997 Trigger Replacement: 手順 3、 1の画像 1
    • The final step is to pull the wires off of the trigger by pulling the wire heads.
    • Be careful while taking off the wires as they can tear.
終わりに
作成者
4人の作成者と共同で作成されました。
Vanessa Duran
メンバー登録日: 09/12/16
113 ポイント
1ガイドが承認済み
チーム
Western Carolina University, Team 1-2, Virtue Fall 2016 Western Carolina University, Team 1-2, Virtue Fall 2016人のメンバー
WCU-VIRTUE-F16S1G2
4 メンバー
8のガイドは作成済み
コメント 1 件
We supply best replacement Dewalt power tool batteries at a wholesale price in Australia. Cordless drill batteries for Dewalt are producted with high test safe circle and chips that give different capacities. We pormise the replacement Dewalt batteries are 100% compatible with the orginal porducts. Full 1 year quality assurance & 30 days money back gurantee! Select cheap Dewalt cordless drill battery by models at http://www.drill-battery-au.com/bestbatt...
drillbatterycomau - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 22
今までの合計 1,869
