必要な工具と部品
Open the chuck jaws to the largest diameter. Remove the interior chuck screw using the T20 Torx screwdriver.
5 の人々がこのガイドを完成させました。
7 件のコメント
I agree with Jan. This does not make sense to me and i have been twisting this stupid thing for 3 days.
Your comment ‘The chuck screw is reverse threaded, which means you will need to unscrew it counterclockwise. ‘ is nonsense.
A normal screw is counterclockwise to unscrew.
What you meant to say was
‘The chuck screw is reverse threaded, which means you will need to unscrew it clockwise. ‘
You might also like to add the the screw is often coated with loctite and very difficult to remove. A high quality tool and plenty of force may be required to remove this screw.
I think the clockwise thing wasn’t that hard to understand, but personally, my chuck screw was actually quite easy to remove so it wasn’t a problem for me
J .Healy -
https://studio.youtube.com/video/Vx37F9q...
Here’s a short video on how to fix a chuck on drill. The screw that holds the chuck to the drill broke and needed to be extracted, and replaced.
