メインコンテンツにスキップ
DeWalt DW660 Bearings Replacement
必要な工具と部品
  1. DeWalt DW660 Bearings Replacement, Bearings: 手順 1、 1の画像 1
    • Pull off the depth guide.
    • If the guide doesn't come away easily, use a twisting motion to pull it from the tool.
  2. DeWalt DW660 Bearings Replacement: 手順 2、 3の画像 1 DeWalt DW660 Bearings Replacement: 手順 2、 3の画像 2 DeWalt DW660 Bearings Replacement: 手順 2、 3の画像 3
    • Hold down lock #1 to prevent the motor from spinning.
    • While holding lock #1, hold down lock #2 as well.
    • Rotate lock #2 counterclockwise to unscrew the collet nut.
  3. DeWalt DW660 Bearings Replacement: 手順 3、 1の画像 1
    • Remove the collet nut and the collet from the device.
  4. DeWalt DW660 Bearings Replacement: 手順 4、 2の画像 1 DeWalt DW660 Bearings Replacement: 手順 4、 2の画像 2
    • Unscrew the four 19mm T20 Torx screws on the motor shroud.
    • Carefully remove the shroud from the body.
    • When removing the shroud, the spring that operates lock #2 may pop out.
  5. DeWalt DW660 Bearings Replacement: 手順 5、 3の画像 1 DeWalt DW660 Bearings Replacement: 手順 5、 3の画像 2 DeWalt DW660 Bearings Replacement: 手順 5、 3の画像 3
    • Unscrew the four 19mm T20 Torx screws on the side of the back end of the DW660.
    • Take apart the back two halves.
    • Using two fingers, pull the black and white power wires from the motor to completely disconnect the back half of the device.
  6. DeWalt DW660 Bearings Replacement: 手順 6、 2の画像 1 DeWalt DW660 Bearings Replacement: 手順 6、 2の画像 2
    • Lift the coiled spring from the back of the brush using a spudger.
    • While holding the spring out of the way, use a pointed spudger to slide the carbon brush up out of the guide.
    • Slowly release the brush spring. It will sit in the brush guide.
    • Repeat this step for the second brush.
  7. DeWalt DW660 Bearings Replacement: 手順 7、 1の画像 1
    • Pull the rotor out of the front of the DW660.
    • Be very careful to make sure the rotor does not collide with the stator. The stator coils or the commutator can be damaged very easily.
  8. DeWalt DW660 Bearings Replacement: 手順 8、 1の画像 1
    • Remove the snap ring from the bearing by using snap ring pliers.
    • This will take some force and the snap ring will act as a spring, so be careful to make sure the ring does not fly off the pliers.
  9. DeWalt DW660 Bearings Replacement: 手順 9、 1の画像 1
    • Pull the black plastic bearing block off of the motor shaft.
    • Remove the ball bearing from the bearing block.
  10. DeWalt DW660 Bearings Replacement: 手順 10、 2の画像 1 DeWalt DW660 Bearings Replacement: 手順 10、 2の画像 2
    • Remove the rubber cap from the bearing.
    • Use the bearing puller to remove the bearing from the shaft.
    • When installing the new bearings, it may help to use a small hammer and a hollow circular pipe with the same outer diameter as the inner ring of the bearing.
終わりに
作成者
3人の作成者と共同で作成されました。
Ryan Owen Rheaume
メンバー登録日: 04/03/15
405 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-7, Isaacson Spring 2016 UMass Dartmouth, Team 2-7, Isaacson Spring 2016人のメンバー
UMASSD-ISAACSON-S16S2G7
3 メンバー
5のガイドは作成済み
コメント 1 件
What size bearing does it take?
James Armstrong - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 827
