はじめに
If you need to replace a part within the drill, then you need to remove the outer shell of the drill. By following this guide you will know how to take apart the drill assembly to get inside of it.
必要な工具と部品
Compress the buttons on either side of the battery and lift the drill away from battery.
ある他の人がこのガイドを完成しました。
2 件のコメント
It's actually a torx #10 and obviously, you dont really need a torque wrench, I got mine apart with my pro kit with no problems.
where is the guide?
no mention of the speed selector or any other internal parts
