はじめに
This guide will walk you through replacing the plastic arms holding the brushes in place. These are both located at the base of the brush motor and are required for electrical connection.
必要な工具と部品
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
