はじめに
The DeWalt D26451 power switch turns the sander on and off. It may not be working because the circuit is out of alignment, there is a tripped breaker, or a stripped wire.
Replacing the power switch may fix your on/off issues. In this guide, we will be teaching you how to replace the switch. You can order a replacement switch here.
必要な工具と部品
Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
ある他の人がこのガイドを完成しました。
