はじめに
It rarely happens, but if the timing belt is broken, it can be replaced quite easily.
Note: It is generally sufficient to remove the base plate. However, removing the side panels is not difficult and you will then have better access to the engine.
必要な工具と部品
The rear panel and side panels are attached with six phillips screws #2. Screw them out.
The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
Lift out the left side piece.
The front panel is secured with four PH2 Phillips screws, two left and one right each. Turn it out.
Use a plastic opening tool to lever off the steam tap.
Carefully pull the front panel about 1 cm forward so that there is a gap between the top cover and the front panel,
Two Phillips screws PH2 hold the lid at the back. Turn it out.
Lift the lid upwards.
This is what the timing belt looks like.
Lay the machine on its side.
The bottom panel is secured with five Torx TR15 security screws. turn them out.
Take off the bottom plate. The toothed belt becomes visible.
Work the steps in reverse order to reassemble your device.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
HelloMacOSさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
