メインコンテンツにスキップ
Dashcam DOD LS300W Battery Replacement
必要な工具と部品
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 手順 1、 3の画像 1 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 手順 1、 3の画像 2 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: 手順 1、 3の画像 3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: 手順 2、 2の画像 1 Dashcam DOD LS300W Battery Replacement: 手順 2、 2の画像 2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: 手順 3、 3の画像 1 Dashcam DOD LS300W Battery Replacement: 手順 3、 3の画像 2 Dashcam DOD LS300W Battery Replacement: 手順 3、 3の画像 3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: 手順 4、 1の画像 1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
終わりに
Once again, thank you for checking out this guide and I hope it helped!
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Pierre
メンバー登録日: 04/02/13
542 ポイント
3のガイドは作成済み
2 件のコメント
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - 返信
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 29
今までの合計 6,352
