はじめに
To assess the quality of wire insulation and crimping: IPC / WHMA-A-620, class 2.
必要な工具と部品
The antistatic coating for the table is cut with a cutter according to the length and width of the table.
The anti-static coating on the shelves is cut with a notch according to the length and width of the shelf.
A hole is punched in the middle of the table cover.
The clip is pressed with a button.
A hole is punched in the left edge of the shelf cover.
The button and shelves are clamped with clamps.
Cut a 30 cm long cord (for a table).
Cut cable 1.3 m long cable (shelves).
The wire is insulated at both ends. Setting the insulation pliers at the 10 mm mark.
A quick-connect contact is clamped to one end of the cord.
The loop contact is pressed onto the other end and a pin with a hammer is hammered onto it.
For both wires, one end is terminated with a quick-connect contact, the other end with a pin with a head.
A 2.5 m long cable is cut (between the pole and the table).
Quick-connect contacts are clamped at both ends.
A bracelet grounding socket is attached to the front of the table, 50 cm from the left edge.
Socket screwed 2 pcs. with hexagonal self-tapping screws.
The cord runs through the inside of the table and the cord is wrapped around the left leg of the table from the inside.
The cord is then routed straight to the left rear leg of the table. From the inside, the cord is wrapped around the leg and routed as close to the center of the table as possible.
After this self-tapping screw 1 pcs. the contact block is placed first on the head and the contact of the loop is placed under the block.
A block with a socket and a self-tapping screw is placed from below under a metal table beam.
The table construction is drilled with a self-tapping screw and a block with a socket loop is screwed on.
A contact pad is screwed horizontally onto the ground pole with a self-tapping screw.
The prepared table and shelf coverings are placed on the table.
The table cover is connected to the contact pad.
The shelf cover is connected to the contact pad.
The table contact pad is connected with a wire to the ground tube contact pad.
After assembly, recheck or complete all wiring connections:
1. The grounding socket of the bracelet is connected to the contact pad and the table frame.
2. The table cover is connected to the contact frame of the table frame.
3. The shelf cover is connected to the contact frame of the table frame.
4. The contact frame of the table frame is connected to the contact block of the ground pole.
2 の人々がこのガイドを完成させました。
