メインコンテンツにスキップ
DYMO LabelWriter 450 Front Cover Replacement
必要な工具と部品
  1. DYMO LabelWriter 450 Front Cover Replacement, Back Plate: 手順 1、 3の画像 1 DYMO LabelWriter 450 Front Cover Replacement, Back Plate: 手順 1、 3の画像 2 DYMO LabelWriter 450 Front Cover Replacement, Back Plate: 手順 1、 3の画像 3
    • Make sure the device is unplugged. Then, turn over the device so that the label is readable.
    • Remove the two 15.7mm screws on the top of the device first, and then the two 26.5mm screws on the bottom (they are in the smaller holes and larger holes respectively) using a Phillips #1 screwdriver.
    • You need a spudger to orient the bottom screws so that they can be removed.
  2. DYMO LabelWriter 450 Front Cover Replacement: 手順 2、 2の画像 1 DYMO LabelWriter 450 Front Cover Replacement: 手順 2、 2の画像 2
    • Once the Back Plate has been unscrewed, you will see the components from the top of the device plugged into the motherboard. You will only have 1-2 inches of clearance to unplug the components from the motherboard.
    • There are four components to unplug: the power cable connector, the two small no-fuss ribbon cable connectors, and the large no-fuss ribbon cable connector. The order does not matter.
    • This device has a blade located within the front panel. When handling the device, be careful not to touch the blade.
  3. DYMO LabelWriter 450 Front Cover Replacement, Front Cover: 手順 3、 1の画像 1
    • Once the back plate is removed, turn the device upright and open the lid.
    • Place your finger behind the front cover, near where the light gray tab is, and lightly pull toward you. The entire front nameplate will pop off.
終わりに
作成者
1人の作成者と共同作成されました。
Jared Finkel
メンバー登録日: 10/09/18
649 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G4, Leahy Fall 2018 USF Tampa, Team S1-G4, Leahy Fall 2018人のメンバー
USFT-LEAHY-F18S1G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 63
今までの合計 5,207
