メインコンテンツにスキップ
DYMO LabelPOINT 100 Rubber Transport Roller Replacement
必要な工具と部品
  1. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 手順 1、 3の画像 1 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 手順 1、 3の画像 2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 手順 1、 3の画像 3
    • Slide the panel release button.
    • Lift the panel.
  2. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Label Tape Cassette: 手順 2、 2の画像 1 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Label Tape Cassette: 手順 2、 2の画像 2
    • Firmly press the cartridge release button with your finger.
    • You may need to hold the cassette and/or entire device still while pressing the button.
    • Lift the label tape cassette out of the device.
  3. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 手順 3、 3の画像 1 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 手順 3、 3の画像 2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 手順 3、 3の画像 3
    • Use Phillips #00 screwdriver to remove three screws
    • Remove blade cutter
    • Use Phillips #00 screwdriver to remove remaining two screws from the battery compartment
  4. DYMO LabelPOINT 100 Rubber Transport Roller Replacement: 手順 4、 2の画像 1 DYMO LabelPOINT 100 Rubber Transport Roller Replacement: 手順 4、 2の画像 2
    • Gently pull the access panel up to separate from the device
    • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
  5. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 手順 5、 3の画像 1 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 手順 5、 3の画像 2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 手順 5、 3の画像 3
    • Use Phillips #00 screwdriver to remove six screws
    • Slowly separate back panel
    • Gears attached to the back panel are not secured and have a tendency to fall out. This will cause difficulty when reassembling
  6. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Rubber Transport Roller: 手順 6、 2の画像 1 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Rubber Transport Roller: 手順 6、 2の画像 2
    • Gently pull rubber transport roller up to remove
    • Replace rubber transport roller
終わりに
作成者
1人の作成者と共同作成されました。
Deborah Canas
メンバー登録日: 09/25/14
122 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 5-2, Mcgee Fall 2014 USF Tampa, Team 5-2, Mcgee Fall 2014人のメンバー
USFT-MCGEE-F14S5G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 1,238
