メインコンテンツにスキップ
DYMO LabelManager 160 Keyboard Replacement
必要な工具と部品
  1. DYMO LabelManager 160 Keyboard Replacement, Batteries: 手順 1、 1の画像 1
    • Place the device face-down to access the battery compartment.
  2. DYMO LabelManager 160 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. DYMO LabelManager 160 Keyboard Replacement, Keyboard: 手順 3、 1の画像 1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. DYMO LabelManager 160 Keyboard Replacement: 手順 4、 2の画像 1 DYMO LabelManager 160 Keyboard Replacement: 手順 4、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. DYMO LabelManager 160 Keyboard Replacement: 手順 5、 1の画像 1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. DYMO LabelManager 160 Keyboard Replacement: 手順 6、 3の画像 1 DYMO LabelManager 160 Keyboard Replacement: 手順 6、 3の画像 2 DYMO LabelManager 160 Keyboard Replacement: 手順 6、 3の画像 3
    • Gently remove the rubber keyboard from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Matthew Jenkins
メンバー登録日: 01/27/16
274 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team 1-4, Sydow campbell Spring 2016 University of Alabama, Team 1-4, Sydow campbell Spring 2016人のメンバー
UA-SYDOW CAMPBELL-S16S1G4
4 メンバー
4のガイドは作成済み
3件のガイドコメント
Group 9: Over all looks great. Screwdriver at top of page should be under tools not parts.
In Step 4 the screws in the second picture 2x 1.2mm should be circled in orange and should be a separate bullet with appropriate coloring.
Possibly add a picture using the spudger, so the user knows exactly where they need to pry.
Fantastic lighting and clear pictures!
Zachary Parker - 返信
Where do I get a replacement key boars
willow williams - 返信
Where did you obtain the parts from as I am having difficulty
Tommy Taylor - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 28
今までの合計 2,293
