メインコンテンツにスキップ
DOSS SoundBox Speaker Replacement
必要な工具と部品
  1. DOSS SoundBox Speaker Replacement, Speaker: 手順 1、 2の画像 1 DOSS SoundBox Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  2. DOSS SoundBox Speaker Replacement: 手順 2、 2の画像 1 DOSS SoundBox Speaker Replacement: 手順 2、 2の画像 2
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  3. DOSS SoundBox Speaker Replacement: 手順 3、 2の画像 1 DOSS SoundBox Speaker Replacement: 手順 3、 2の画像 2
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
終わりに
To reassemble your device, follow instructions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Brendan Harkreader
メンバー登録日: 09/27/18
543 ポイント
3のガイドは作成済み
チーム
Linn Benton Community College, Team S1-G3, Johnson Fall 2018 Linn Benton Community College, Team S1-G3, Johnson Fall 2018人のメンバー
LBCC-JOHNSON-F18S1G3
4 メンバー
7のガイドは作成済み
1件のガイドコメント
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 41
今までの合計 3,301
