メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DOSS SoundBox Motherboard Replacement
必要な工具と部品
    1. DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: 手順 1、 3の画像 1 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: 手順 1、 3の画像 2 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: 手順 1、 3の画像 3
      • Use a small plastic opening tool to gently lift the side of the grille.
      • Gently slide the tool to the front of the speaker.
      • Repeat the process on the bottom of the grille.
      • Gently pull the grille off of the speaker enclosure.
      • Pry with caution, for the grille is fragile.
      FixBotに聞いてみる
      コメントを追加
    1. DOSS SoundBox Motherboard Replacement, Speaker: 手順 2、 2の画像 1 DOSS SoundBox Motherboard Replacement, Speaker: 手順 2、 2の画像 2
      • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
      • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
      • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
      • Using a Magnetic Mat throughout this process will help prevent losing screws.
      FixBotに聞いてみる
      コメントを追加
    2. DOSS SoundBox Motherboard Replacement: 手順 3、 2の画像 1 DOSS SoundBox Motherboard Replacement: 手順 3、 2の画像 2
      • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
      FixBotに聞いてみる
      コメントを追加
    3. DOSS SoundBox Motherboard Replacement: 手順 4、 2の画像 1 DOSS SoundBox Motherboard Replacement: 手順 4、 2の画像 2
      • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
      • The speakers are ready to be removed and replaced.
      • Ensure that the device is turned off when handling bare wire.
      • Soldering iron is very hot.
      FixBotに聞いてみる
      コメントを追加
    1. DOSS SoundBox Motherboard Replacement, Battery: 手順 5、 2の画像 1 DOSS SoundBox Motherboard Replacement, Battery: 手順 5、 2の画像 2
      • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
      • Use a magnetic mat to prevent the loss of screws.
      FixBotに聞いてみる
      コメントを追加
    2. DOSS SoundBox Motherboard Replacement: 手順 6、 2の画像 1 DOSS SoundBox Motherboard Replacement: 手順 6、 2の画像 2
      • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
      • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. DOSS SoundBox Motherboard Replacement: 手順 7、 1の画像 1
      • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
      • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
      • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
      FixBotに聞いてみる
      コメントを追加
    4. DOSS SoundBox Motherboard Replacement: 手順 8、 1の画像 1
      • De-solder the connections from the battery to the circuit board.
      • If you do not already have a replacement battery, you can purchase one here.
      FixBotに聞いてみる
      コメントを追加
    1. DOSS SoundBox Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
      この手順で使用する道具:
      • Follow the steps leading up to the actual battery removal, but do not actually remove the battery.
      • Remove the two 3/32" screws that attach the motherboard to the battery compartment using a JIS #00 screwdriver.
      • Use your fingers or a pair of tweezers to remove the clip holding the ribbon connector in place. The connector is indicated with an orange marker.
      • Be sure not to apply excessive force on the ribbon connector, as it can break.
      • Find the speaker connector, indicated by a yellow circle, and using your fingers disconnect it.
      FixBotに聞いてみる
      コメントを追加
    2. DOSS SoundBox Motherboard Replacement: 手順 10、 2の画像 1 DOSS SoundBox Motherboard Replacement: 手順 10、 2の画像 2
      • Locate and remove the two 3/32" screws, indicated by red markers, that fix the motherboard to the speaker enclosure.
      FixBotに聞いてみる
      コメントを追加
    3. DOSS SoundBox Motherboard Replacement: 手順 11、 3の画像 1 DOSS SoundBox Motherboard Replacement: 手順 11、 3の画像 2 DOSS SoundBox Motherboard Replacement: 手順 11、 3の画像 3
      • Using the plastic opening tool, gently begin to pry the circuit card away from the speaker enclosure.
      • There is adhesive on the top of the motherboard, use caution while prying to avoid breakage.
      • Using your fingers, you can now remove the motherboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Cassandra Remsing
メンバー登録日: 10/02/18
136 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team S1-G3, Johnson Fall 2018 Linn Benton Community College, Team S1-G3, Johnson Fall 2018人のメンバー
LBCC-JOHNSON-F18S1G3
4 メンバー
12のガイドは作成済み
6件のガイドコメント
Cassandra, the million dollar question is dWhere can i buy the motherboard for the SiundBox Doos.
please let me know at rubenalexander2611@hotmail.com, ahora todo lo mandan de la china please, a ver si me das una pagina web.
Ruben Diaz - 返信 共有
As Cassandra said before,,,,WHere we can find the parts??? is it any possibilities ?
bunker1312@gmail.com
bunker1312 - 返信 共有
Where to buy your motherboard for doss torch Bluetooth speaker
smoothjobbrian - 返信 共有
Ffs, Where do you get the board? Pretty useless writeup if there's no known location to aquire parts.
Christopher Cox - 返信 共有
I have taken the motherboard out. Where can I purchase another one as I don't see any link for that?
Paul Doran - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 93
今までの合計 6,547
