メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DOPO 10.1 Tablet Dual .3 mega pixel Camera Replacement
必要な工具と部品
    1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 手順 1、 3の画像 1 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 手順 1、 3の画像 2 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 手順 1、 3の画像 3
      • You will have to remove the back of the tablet. To do this, take the plastic opening tool, and insert into the side of the tablet and twist. This will pop off the side.
      • Slowly pull up on the cover until it is completely off.
      FixBotに聞いてみる
      コメントを追加
    2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 手順 2、 3の画像 1 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 手順 2、 3の画像 2 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 手順 2、 3の画像 3
      • You may notice that the battery is in the way. No worries, it is easy to move. All you will need to do is to gently lift up on the battery with a small constant pressure to release it from the adhesive.
      • Carefully put it off to the side.
      • Once the battery is removed you will see a gray wire. Lightly lift up, and move it out of way.
      FixBotに聞いてみる
      コメントを追加
    3. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 手順 3、 3の画像 1 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 手順 3、 3の画像 2 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 手順 3、 3の画像 3
      • Locate where the camera is plugged into the motherboard. It should be on the left side of the motherboard just above the center.
      • Once located lift the black lever on the right side of the connector. This will release the camera.
      • Once the lever is lifted, pull out the camera by gently tugging the cameras connector tape.
      FixBotに聞いてみる
      コメントを追加
    4. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 手順 4、 3の画像 1 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 手順 4、 3の画像 2 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 手順 4、 3の画像 3
      この手順で使用する道具:
      • Remove yellow tape that is securing the camera to the back cover.
      • Now take tweezers, and gently grab one of the cameras. Once grabbed, begin to twist to remove from device. Do this for both cameras.
      FixBotに聞いてみる
      コメントを追加
終わりに
For information you can go to http://www.doublepowertech.com/download/...
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Kaitlyn Hayes
メンバー登録日: 01/21/15
414 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 5-2, Brown Winter 2015 USF Tampa, Team 5-2, Brown Winter 2015人のメンバー
USFT-BROWN-W15S5G2
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 29
今までの合計 659
