メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DJI Phantom 4 Advanced Remote Controller Power Button Replacement
必要な工具と部品
  1. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 2、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 2、 2の画像 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 3、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 4、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 4、 2の画像 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 5、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 5、 2の画像 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 手順 6、 3の画像 1 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 手順 6、 3の画像 2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 手順 6、 3の画像 3
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 7、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 7、 2の画像 2
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 8、 1の画像 1
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
  9. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: 手順 9、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: 手順 9、 2の画像 2
    • Carefully remove the plastic. This will help you gain access to the power button panel.
  10. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 10、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 10、 2の画像 2
    • With a Phillips #00 screwdriver, remove the two screws on the power button panel.
  11. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 手順 11、 1の画像 1
    • Gently pull the power button out from the panel. Replace it with a new one.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Angel Cortez
メンバー登録日: 10/02/18
246 ポイント
2のガイドは作成済み
チーム
Linn Benton Community College, Team S1-G4, Johnson Fall 2018 Linn Benton Community College, Team S1-G4, Johnson Fall 2018人のメンバー
LBCC-JOHNSON-F18S1G4
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 1,036
