メインコンテンツにスキップ
DJI Phantom 4 Advanced Remote Controller Battery Replacement
必要な工具と部品
  1. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 2、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 2、 2の画像 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 3、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 3、 2の画像 2
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 4、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 4、 2の画像 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 5、 2の画像 1 DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 5、 2の画像 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Battery: 手順 6、 1の画像 1
    • The battery is attached to the back plastic, and is towards the bottom of the remote.
    • Unplug the cord that is connected to the bottom of the main board.
  7. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 7、 1の画像 1
    • After the cord is unplugged, remove the battery by lifting upon the plastic cover, which the battery is attached to.
  8. DJI Phantom 4 Advanced Remote Controller Battery Replacement: 手順 8、 1の画像 1
    • Once the cover is off you can access the battery.
終わりに
8 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
cade knott
メンバー登録日: 10/02/18
481 ポイント
3のガイドは作成済み
チーム
Linn Benton Community College, Team S1-G4, Johnson Fall 2018 Linn Benton Community College, Team S1-G4, Johnson Fall 2018人のメンバー
LBCC-JOHNSON-F18S1G4
3 メンバー
12のガイドは作成済み
4 件のコメント
Grrrrrreat Job!
Rick Artman - 返信
Wo kann ich den Akku bestellen? Danke für die Hilfe!
Xl S - 返信
does someone know where to buy the akku?
Xl S - 返信
Ich habe ein Erzatz Akku eingesetzt mit den gleichen Strom Werten, beim aufladen stelle ich fest das der Akku nicht ladet..
Es blinkt bloß ( schnell) auf einer LED.
Wo kann die Ursache liegen.
Matthias Meier - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 22
過去 30 日: 122
今までの合計 12,204
